Hi all,
I'm a little new in the avo world. And I would like to know a few things. I was looking around on the forum and i notice that you can change the SG.DAT file. Ik would like to make a few shape myself. But the problem is I don't understand the coding.
Is there any information about making a shape? A tutorial perhaps?
greeting Math
Editing shape file
I searched a lot.
But my problem is I don't understand what in it.
For example:
What does al there numbers mean.
I found this in de SG.DAT file
But what if I want to make somthing width RGB colors? that not listed... But I gues 20 = Red ; 21=Green ; 22=Blue is this correct?
Also whats the difrence between PATERN and SHAPE ...
How do I use PATERN ?
For example:
SHAPE "Dimmer Saw1" "SAW"
8 255 64 0 0 1 0 128
SENDWhat does al there numbers mean.
;SHAPE <"name"> <"pattern">
;<Channel, 1=Color wheel, 2=Cyan, 3=Yellow, 4=Magenta, 5=Pan>
;<6=Tilt, 7=Iris, 8=Dimmer>
;<Ampitude (0..255)>
;<rate, 512/(rate*16)=seconds>
;<ramp 0=Off 1=ON>
;<repeat-repeats pattern after repeat number of fixtures>
;<spread-how the instruments are spread across the pattern, 0=even spread>
;<phase-0..360, position where the pattern is picked up from>
;<offset-base position for the channel 0..255)>
The numbers use the same order as the attributes in personality files, which also don't mention RGB. But it is as follows:
Pattern is the dmx offset in hex applied +/-127 to the attribute specified in the shape definition. Only one pattern can be used per shape but each attribute can contain different start phase thus allowing circle (using the same pattern with phase for pan/tilt) or rainbow with phase on the colour components. The pattern offset will be modified by size where 255 gives the full range.
1-Colour Wheel1
2-Cyan
3-Magenta
4-Yellow
5-Pan
6-Tilt
7-Iris
8-Dimmer
9-Gobo1
10-Gobo2
11-Gobo1 Rotate
12-Focus
13-Gobo2 Rotate
14-Colour Wheel2
15-Shutter
16-Prism
17-Zoom
18-Effect
19-Frost
20-Red
21-Green
22-Blue
Oh thx for the information.
I'm just messing around right know. I have a simple idea for a shape.
In words: (I wanne use is on showtec octostrips)
Al the strips are blue an there is running a red block across. so when de red block passes by blue has to go to 0 and red to 255.
I made this:
Now I want to test it with de pearl simulator an visualiser. I reload my shape file, but my new created shape is not listed! Why?
I made this:
SHAPE "Blue/Red" "running"
22 255 64 0 0 1 0 128
20 255 64 0 0 1 180 128
SENDNow I want to test it with de pearl simulator an visualiser. I reload my shape file, but my new created shape is not listed! Why?
Umm. I'm pretty sure there is no option to choose directory unless something was changed.
System/Utilities/Load Shape File. In my version it either finds it or not. There is no file dialog. I am almost certain it must come from a floppy since that's how it would have worked on the console. Potentially you might be able to remap a drive letter? Unfortunately I have no time to look into this now.
Tumbleweed
Shape & Personality File Summaries
I've picked up a lot of details on file syntax and design for Shape and Personality files from various posts on this forum. Thanks to those of you who have contributed.
Is there a detailed summary document available somewhere from Avolites? I would also find it extremely useful to have a List of the standard Shapes with a brief description of what they do. When programming a show, I rarely have time to experiment with shapes I haven't used before, especially when the names don't give me much clue what they act on.
Users browsing this forum: No registered users and 125 guests
