Hello, I work on a stage with the Pearl Expert, and sometimes it freezes during the show, and as you can imagine, it's not a beautiful thing to watch.
By freezing I mean that all controls get "stuck", I cannot change anything, but it keeps the previopus DMX output.
So I figured that it only freezes when I select all the 20 Mini-spots 250 (I often use the Takeover mode, still didn't have that much programming time) and change the color. I thought it happened because of a memory overflow, but yesterday, while quick programming and testing, it froze when I changed only the color to red.
So my question is, why is this happening? Is that a fix or some workaround?
Thanks in advance.
Pearl Expert freezes
When it freezes can you move the mouse around on the VDU screen?
If so then open up USB expert and check that you are getting key presses.
I do not believe that upgrading the software will fix the problem but switching to Titan mode would be a good idea. I would suggest that you run the latest v1.2 recovery disk on our website as well.
