Just wanted to report that the Expert froze on me twice, within about half an hour. By froze, I mean it continued to output all running PB's, but on lowering they continued, firing new PB's wouldn't run and the GM had no effect.
At the time I didn't think to use the panel reset button, I just restarted the software and all returned to normal. The only thing I was doing at the time was giving some flash buttons a work out. The second time it happened, I don't recall doing anything unusual and this time after a few seconds it sorted itself out.
Is the a log file anywhere that would be helpful to someone (that would no what it means) ?
Should I be concerned? Or not worry an update to V1.2?
Cheers,
Andy
Expert Titan 'froze' ...twice
John Peel
www.iadwm.com
John Peel
www.iadwm.com
In all honesty, I can't remember if the Autosave was on or off, but I should have membered to check, as I also pointed that out to someone in another thread! ....You (SL) as it happens...!
I remember doing a manual save as I named the show. I'm not with the desk now, but will check later...
As for software version: that was me getting confused, I haven't been to Avo home page for a while and was looking for something and saw the download flag, just thought there was and update. I only noticed the date after posting.
I was concerned a bit, but I didn't see any need in ranting on here...
"this shouldn't happen...bla bla ". I almost expect software to play up now and then, especially with something relatively new.
Had it continued to play up for the rest of the event that would have a completely different matter! It didn't.
Cheers,
Andy
Cheers,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Nick Forro
I highly recommned that you load V1.2 into the desk.
This should sort this issue out.
Ideally you would download and make yourself a V1.2 recovery disk.
you can get this from the page below;
http://www.avolitesdownload.com/Downloa ... tTitan.stm
Running the recovery disk will format the drive and remove any potential viruses that may have got into the desk.
We recommend that users do this periodically to 'clean out' the hard drive.
Otherwise the work around for the original problem is to either have the virtual panel open or select a fixture and move the playback fader again to regain control of the locked up fader.
I thought I was on 1.2 but after checking (properly) it turned out I wasn't !
But now I am....
Although, I still don't have control over LCD brightness and contrast, the options are grayed out....
Also, I went to try and name a Vis Theatre, but the keyboard wouldn't let me enter anything, I'm sure I read a 'how to' to get the keyboard to release to Windows but can't find it now, it was a very recent thread...
Any pointers?
Cheers,
Andy
But now I am....
Any pointers?
Cheers,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
1.2 is most easily recognised by the change in colours in the HUD, for anyone else who might be in doubt.
Make sure you have updated panel software.
LCD contrast and brightness should be in system menu. When in Usb Console you must select screen panel on the left but there should be no need to use this any more.
For keyboard press escape.
Thank you, all is fine....
The HUD display is much easier to read, although I'm not that keen on the colours!
Not having remembered all the notes for 1.2 I didn't look in System
...I know now.
I hadn't selected <screen panel>
Thought I had tried <escape> it seemed obvious (or I was just remembering that thread), either way, clearly I hadn't tried it as it it works just fine.
Thanks!
Andy
...I know now.
Thanks!
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
LOL....
Or make them user definable?
It was in the release notes I read about the <escape> button for the keyboard...now that I've read them
Andy
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Best not, eh?
Perhaps V1.3 will have a more invigorating gamut than Sandy Taupe...lol
Cheers,
Andy
Cheers,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Apologies (to the HUD designer).... I can't believe I am going on about the colours! It still all feels like luxury, after the 2004 display!
Andy
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Users browsing this forum: No registered users and 73 guests
