gobo rotation in palet
vbarie
Postby vbarie » 02 Aug 2009, 15:39
is it possible to program a gobo rotation whitout programming the gobo. in the titan software.
Postby niclights » 02 Aug 2009, 16:14
Yes. Just make sure you select record by channel mode.
vbarie
Postby vbarie » 02 Aug 2009, 16:38
i no howe it works in the classic mode. But in titan you have tot select if you want to record in channel or in fixture mode when recording a que. But when i want to record a palete i can only select which atribute i want to program. But the gobo rotation and the gobo is on the same button.
Postby niclights » 02 Aug 2009, 17:24
In Classic it is always record by channel.
Which version of Titan are you using? IIRC 1.1 should have a softkey within the store palette menu to toggle record mode. I think 1.0 was done by a second press of the attribute key but this was confusing.
Marquz
Postby Marquz » 04 Sep 2009, 10:02
I have the same problem...
It´s not woking in titan yet i think...
/M
Postby niclights » 04 Sep 2009, 13:17
You must ensure store palette is set to 'channel in programmer'. By default it is 'group in programmer'. To change this enter store palette menu and toggle mode with softkey E.
Olie
Site Admin
Postby Olie » 04 Sep 2009, 17:33
It is better to set the record mode to "Mixed", in V2 this will be the default mode.
Users browsing this forum: No registered users and 105 guests
