Hallo,
I'm quite new to the pearl but I did think I'd got the patching allright it appears I don't.
I got my hands on some old showtec MK II challengers and I wanted to patch them. So i followed the normal steps but each I try to select the fixtures from showtec I get the same message :
Error Allocation out of memorie
and the my pearl freezes
The strange thing is this only happends when I select the showtec fixtures all others just work perfectly.
It used to work perfectly (about 2 months ago).
Anyone knows what causes this or how I can fix it ?
I use a pearl 2004 upgraded to the 2008 version.
Greets,
Rick
Showtec Patching errors
David.Hunt
David.Hunt
Yes I wiped the pearl 2 times and it said the memory was 99 % empty.
Then I tried to patch it : turned it in program mode --> patch --> choose fixture --> USBO1 --> showtec then is started cataloging and it froze.
I wiped it again en tryed to sychronise the fixtures.
Turned it in system mode --> USB stick options --> synchronise fixtures --> cataloging please wait, and then is said synchronise failt.
and both times all other fixtures worked just fine.
Thanks again,
Rick
Thanks again,
Rick
Users browsing this forum: No registered users and 123 guests
