Pearl 2k - Two preset mode
ekul1978
Postby ekul1978 » 14 May 2009, 11:55
Hi, im hoping you guys can help. I have a Pearl 2000 running 2004 software. Ive tried to set up the desk to use the two preset mode so I can run the first 30 channels on both top and bottom faders, but I cant seem to get it to work. Ive followed the instructions in the manual but no luck - am I missing somthing obvious or is it more likely that my desk has a fault?
Any help or advice would be much appreciated.
Luke
Postby niclights » 14 May 2009, 14:11
Have you set user setting to two preset mode and turned key to run?
This will only work in run mode, not in program.
ekul1978
Postby ekul1978 » 14 May 2009, 14:17
yeah ive changed the user setting 1 to 'two preset mode' and tried it in run but nothing seems to work.
luke
Postby niclights » 14 May 2009, 15:09
Are your fixtures patched on the lower bank? ie. Handles 1-30?
Users browsing this forum: No registered users and 60 guests
