I am having problems controlling Zero 88 Chilli Install Dimmers using a Saphhire 2000.
The desk controls Mac 550's and Scrollers on Line B fine, but trying to control dimmers on any Line results in the following problem:
When a fader is put up with a dimmer patched to it, there is a 3/4 second delay then the lantern snaps to full, when the fader is put back down, there is a 3/4 second delay then the lantern snaps back to zero.
Everything works perfectly when using the venues own desk, a Zero 88 Alcora.
Any suggestions would be grately appreciated.
Regards
Matt Evans
mail@mattevans.co.uk
Sapphire and Dimmer Problem - Vert urgent
In emergency there is a 24hr number: 07831 178888
The first thing I would do is try resetting the console, just in case.
I can't think what could cause this, other than something at the dimmer end, or some DMX incompatibility.
Does it do it when programmed to a playback? Does it do this when using flash?
Tumbleweed
Nick Forro
