Very old Rolacue 60...
Porky
Postby Porky » 05 Nov 2008, 14:36
Hi everyone,
I have a big problem with an old Rolacue 60 board (from the late 80's):
When programming a memory, the board adds similar channels to the memory which I programmed....for example:
- Programming Channel 10 to memory
- Fader channel 10 on 100%
- Store to memory 1
- If you now push up memory fader 1, Channel 10 is on 100%, but also Channels 9 and 8 (on 80% and 60%)
All the same on each memory with each combination of channels you try to programm.
The Chasersection works fine, no problem there.
Anyone here any ideas what I can check to debug the memory section ?
i love this desk very much, but with this bug I'm not possible to work with it....
Thanks for your help & greetings from Germany
Porky
Porky
Postby Porky » 21 Nov 2008, 11:11
Nobody any idea ??? :(
avonewbee
Postby avonewbee » 22 Nov 2008, 13:18
Das dauert hier immer ein bisschen bis jemand antwortet.
Leider!
Translation:
Sooner or later someone will answer your question!
greetings from germany
JB Toby
Postby JB Toby » 23 Nov 2008, 09:18
Most forum dwellers are to young to know the RQ60
Anyhow, you are looking at a hardware issue, either the D>A is not doing its thing or the multiplexer both on the D>A or A>D card
I used to exchange chips with is neigbour and see which one moved the problem.
Anyhow if you give Adam a call at Avolites he can help you
J.B.Toby
Technical Director
Avolites limited
184 Park Avenue Park Royal
London NW10 7XL UK
Tel +44(0)20 8965 8522
Tel +44(0)20 8965 0290
email: jb "insert AT sign here" avolites.com
sory need to fend of spam
