Hello. New to this forum. Just wanted to ask a question that may have a stupidly easy answer but i'm stuck.
On the tiger you have 30 handles at the top but if I wanted to patch 35 dimmers to the first set of handles on page 0 of the fixtures i can by pressing "avoshift" for the last 5. Not a problem with that.
When it comes to recalling the dimmers using the handles i would assume that you press the fixture page so it's flashing (eg the avoshifted 5 dimmers) and use the handles the raise and lower the level of those 5 dimmers patched there. This doesn't work.
Is there any way of making this work or for any avoshifted dimmer do i have to select the swop button and use the wheel to spool the dimmer up?
As i said, may be an easy answer just getting stuck,
Cheers
dan
Pearl Tiger Question....
I can't answer about whether there will be any further development, but the way you are doing it is the only way. Maybe you would be better using another fixture page if handles are available?
For chase speed this is normal operation on Pearls. To store the speed you must use chase parameters/save speed in program mode (chase must be connected).
