Shape Generator, too fast and shaky, cant get a smooth shape
Billyserious
Postby Billyserious » 03 Aug 2008, 08:41
Hey there, Im a returning Avo user now on a Tiger. Im running 8 kryptons and everytime I try and apply a shape like Circle 1, they will kind of just pan and tilt in a seemingly random very fast and very tight way.
I try to adjust size and speed, and it seems to have very little effect. Still very shaky and obvious.
I seem to remember it being very easy with my previous Pearl, on mac 500's, just apply a shape and it got nice and slow and smooth. Is it a setting on the kryptons themselves that could be causing the issue? Am I missing something obvious?
On a side note, the same happened when I tried dimmer shapes, just kinda jerky random flashing. When I applied any other kind of shape (diamond, square) The fixtures did nothing.
Any advice will be greatly appreciated!
Postby niclights » 03 Aug 2008, 17:05
Do you have the fixtures set to the correct mode for the personality you are using?
Billyserious
Postby Billyserious » 03 Aug 2008, 17:44
Yes, 16bit extended and patched as such
Postby niclights » 03 Aug 2008, 19:47
I can only think that there is something wrong with the shapefile.
Try loading a new one. Easiest way is probably to download any aps disk and extract the sg.dat file. Place on a stick and use 'load new shape file' function from system menu (hopefully it is still there and reads the file from usb ok!)
Do a quick soft reset of desk after loading and see if it solves.
Billyserious
Postby Billyserious » 04 Aug 2008, 09:35
Fixed.
Solution was just to load a new shape file from the actual console memory. Apparently it wasnt loaded right out of the box. Everything now works fine, thanks for the info!
