Deleting show
David Boots
Deleting show
Postby David Boots » 22 Jul 2008, 13:46
I have a corrupted file. Is it possible to delete 1 or 2 time stamps within a show file or would I have to delete the entire file? Console is Pearl 2008.
Postby niclights » 22 Jul 2008, 19:37
I don't think there will be any problem in deleting individual files. If you view the directory structure on a PC it should be clear. If necessary you can edit the .xml reference files. Without having some example files in front of me I can't remember if you need to or not.
Olie
Site Admin
Postby Olie » 01 Aug 2008, 09:54
Doing what Nick suggests would mean removing the memory stick from the console and as it is glued in you may find this tricky.
I am afraid you can only delete whole shows not histories within a show. I would suggest loading a good version in and then saving it with a different show name. You can then delete the old show.
Postby niclights » 01 Aug 2008, 20:21
Sorry, I did assume it would be on an external stick.
David Boots
Postby David Boots » 01 Aug 2008, 23:42
Thanks Olie and Nick. That is exactly what I ended up doing. Thanks for the reply.
Users browsing this forum: No registered users and 60 guests
