fade strobe speed memory (expert)
davidk
Postby davidk » 04 Jun 2008, 17:25
Is it possible to create a memory which starts at strobe function at zero and fades up to 100% at the top of the fader? (with mac 250's)
I thought it would be pretty easy, but I couldn't find it in the manual.
And more important? How do I make it?
Thanks in advance,
David
Postby niclights » 04 Jun 2008, 18:37
Use mode2:
Set 'record by channel' mode.
[clear] (to ensure programmer is empty)
Select fixtures.
Select shutter attribute and set to 100%
[memory]
numeric key 2
Empty playback swop to store.
Re-set shutter value to zero.
[clear]
Now the playback should function as you require (raise intensity to see, obviously!)
Note that the method used above is a shortcut to storing a mode 2 memory. It is also accessed after storing via [edit times]/toggle mode softkey/[enter]
davidk
Postby davidk » 04 Jun 2008, 20:02
niclights wrote:Use mode2:
Select fixtures.
[memory]
numeric key 2
[clear]
K, thanks (Y) I'm going to try it this friday, thanks.
AtmosphErik
Postby AtmosphErik » 11 Jul 2008, 15:50
adding to this, any attribute that needs to respond to a "mode 2" playback should be set as "fading" , not "instant", in the patch, or it won't "turn off" when you bring the fader back down...
Erik Steijvers
Dutch Guy Design
" If I want your opinion, I'll give it to you..."
