I have just downloaded the above and when run there is an exception at the bottom of the screen starting "c:\documents and settings\jonathon salzedo\projects etc"
Have you got the right version posted as I assume these are settings personal to whoever Jonathon is!!!
Download Visualiser 6.08 WinXP Problem
Richard Simpson
Thanks for the screen shot.
This problem is due to there being an Extensions file but no Personality file. To resolve this problem you need to delete two folders in the Vis program directory called “Extensions†and “Personalitiesâ€. Then download the latest Visualiser personalities from our website at http://www.avolitesdownload.com/Personality%20Library/Downloads/Vis%20&%20R20%20upgrade.exe. Once you have downloaded the upgrade you then need to run it. Once it has finished successfully you can now run Visualiser and you should find that your problem is resolved.
Users browsing this forum: Google [Bot] and 16 guests
