diamond 4 relay question - maybe a dumb one
new13dad
Postby new13dad » 18 Mar 2008, 19:31
always on relay curve... is this even the case when i press clear?
and if it does go off, is there a way to stop it from doing so?
and i apologise if this is obvious :cry:
Postby Gregory » 18 Mar 2008, 22:27
With the always on relay curve, the output for that channel should be 255 regardless of the input level. The clear button usually sets the level to 0 however after the curve is applied this still gives an output of 255. As far as I am aware the dimmer should not go off for any reason with that curve applied.
new13dad
Postby new13dad » 20 Mar 2008, 12:27
thanks. I want to be sure before i get stuck in the situation.
i have to supply moving light power via Str**d contactors (long story!) and i really can't have them going off every time i press clear!
Olie
Site Admin
Postby Olie » 20 Mar 2008, 13:05
If you use this curve the desk will always keep the channel at full. It should not go off so that is fine.
I think more problematic is your choice of dimmer ;-)
new13dad
Postby new13dad » 20 Mar 2008, 15:12
oh I know. I know! :cry: :cry: :cry: :cry:
