R20 Personality Builder Software
Raúl
Postby Raúl » 21 Dec 2007, 12:24
Ah, ok that's it... I thought that you was talking of something else... that's already running on the soft.
The only thing I've missed are the new atributtes for RGB, I'll implement it asap.
Thanks for your support
Raúl Gómez
ILUMINACIÓN ALBADALEJO SL
http://www.albadalejo.com
iadwm
Postby iadwm » 21 Dec 2007, 12:49
Raúl wrote:Try again Andy,
Both ways worked fine for me... maybe you try it in a server's "coffe time" hehe
Best regards,
All seems fine now.
Thanks again.
Andy
John Peel
www.iadwm.com
Raúl
Postby Raúl » 02 Jan 2008, 21:08
Happy New Year to all!!
In order to comply with Pearl 2008 v1 software library system (thanks Olie) a new version is released (v1.3)!
It includes new attibute type tags for Red, Green and Blue channels for RGB fixtures. That implement forced to redone some parts of the software, specially Palettes creator and channel set-up, and changed a little bit the behaviour of the software in some cases. It's thoroughly tested and works perfectly, but anyway, if you experience some rare things or errors just tell me opr send me the generated crash log.
Old files created with this software are fully compatible but I really recommend to review it, because the program will tweak some values there and you'll be sure that is Pearl 2008 software compatible.
Please update your copy using the "Check for updates" button or just download it and install it!
Have fun!!
Raúl Gómez
LD_Peter
Postby LD_Peter » 06 Jan 2008, 22:52
I´ve downloaded the R20 builder, but i can´t seem to be able to open .r20 files.
I´ve "checked for updates" too be sure that I´ve got the latest version 1.3 but it doesn´t work anyway.
Raúl
Postby Raúl » 07 Jan 2008, 09:00
Open R20 files is not allowed still, because I'd to do some changes on the programming and I'm testing it, I'll release it when it become as stable as I can. Right now it's under final steps, should be available soon...
Sorry for the inconvenience.
Raúl Gómez
Raúl
New version 2.0 available
Postby Raúl » 06 Feb 2008, 22:51
Hello everybody!
I'm so glad to anounce you that new version 2.0 of the R20 personality builder is released!!
And, finally, it includes R20 file editing capabilities. Now you can open your R20 files to view/edit!!
Here some adds on new version refearing to previous version:
- Added edit R20 files capabilities
- R20 files are now automatically associated with this application
- Internal structural major changes
- New R20 syntax errors analyser
- Added Release Notes viewer and manager
- Fixed bugs on generating process
- Fixed bugs on Color Mix system (autoPalettes)
- Fixed some language problems
- Redone Macro system (new way of create)
- Some internal tweacks on PT picker
- Sample option removed
- Unlocked Range Descriptions to be able to add formulas
- Custom Shapes internal works
- Some GUI fixes and other bugs fixes
And it's much more faster and good looking than old versions.
KNOWN LIMITATIONS:
- Right now it's not abe to edit Macros, it'll be possible very soon
NEXT STEPS:
- Edit Macros
- Create custom Shapes
- AutoSend files to Avolites team
- Create D4 files???? :)
As always, this version was thoroughly tested, but anyway, if you find some problems or crashes, just use the crashlog and send me the file. I always recommend to test your generated files before the gig.
Feel free to let me know your comments and impressions.
Enjoy!! :D
Raúl Gómez
Postby niclights » 07 Feb 2008, 00:15
Looks very nice. I will try and play with it soon.
iadwm
Postby iadwm » 07 Feb 2008, 04:56
Hi Raúl,
Did you know that UPDATE from V1.3 recognizes that there is a new version available (2.0.099), but installs V1.3 again.
I used the link to download V2.0
Thanks !
Regards,
Andy
John Peel
www.iadwm.com
Raúl
Postby Raúl » 07 Feb 2008, 08:43
Thanks Andy,
This issue is solved in last version you downloaded (v2.0.99)
Anyway, new version v2.0.100 is posted to solve other minor issues.
Just update one more time!
Regards,
Raúl Gómez
iadwm
Postby iadwm » 07 Feb 2008, 18:23
Cheers....
(looking forward to shapes :D )
Andy
John Peel
www.iadwm.com
Raúl
New version (2.1)
Postby Raúl » 21 Feb 2008, 23:09
Hello everybody!
A new version (2.1) is ready to be released!
Just update your version or download at http://www.albadalejo.com/raul/software/R20PB.zip
This new version implement all Macro features (reading, editing and generating), not included in 2.0.
Now you can read all macros from an R20 file, and edit them.
This was the last feature regarding the R20 editing; surely a few tweacks will follow, but no major implements in this way. Next works will go to custom Shapes creator/editor.
Have fun with R20PB!!
Raúl Gómez
juanfran
Postby juanfran » 22 Feb 2008, 09:46
Your program is spectacular.
Yesterday same he was sending a post because he needed the library of a device urgently. On the same morning I have created it with your program. I am available to help you in what you need, thank you.
Raúl
Postby Raúl » 22 Feb 2008, 14:23
juanfran,
Me alegro de que te guste, y sobretodo, de que te haya sido útil. Esa es su función.
Gracias,
Raúl Gómez
zahoorjury
1.3 to 2.1 version
Postby zahoorjury » 29 Feb 2008, 13:25
hi raul just want to say LONG LIVE RAUL, the problem is that after upgrading with 2.1 version when i verify in ABOUT option on the main window , its still shows version 1.3 ( Build 91 ), is it ok or i have to reinstall the software for the new look.
iadwm
Postby iadwm » 29 Feb 2008, 14:15
Don't use UPDATE, just install the new version from the link. This issue is covered a few posts up the thread.
HTH
Andy
John Peel
www.iadwm.com
Users browsing this forum: No registered users and 109 guests
