R20 Personality Builder Software
gnamusic
Postby gnamusic » 17 Nov 2007, 14:11
ok i understand.
something i want to know about this software, me and my bos trying to learn how your software works, how can i edit the .r20 files ? its only can edit for rbg files. i just want to learn from begining about the scripts. mean while i printed out all azure 2000 manual i just still dont understand how the scripts working on azure 2000.
yes, i came from asia and another member of this forum also said that in asia alot of brand moving head. i knew that sceene setter from behringer can controlling these moving head, but im working on azure 2000 and i want to work only for azure 2000, too naif huh ?
thats fine with me, only azure 2000 can controlling moving head with different address more than 2 moving heads! be frankly, only azure 2000 lighting mixer that i had. poor i am.
so back again about this software, how can i edit another r20 files using this software, there's something i missed ?
Raúl
Postby Raúl » 19 Nov 2007, 08:48
gnamusic,
Right now you cannot edit or open an existing R20 file, that's a feature I'm testing still. I hope it will be available soon with many other features.
Raúl Gómez
ILUMINACIÓN ALBADALEJO SL
http://www.albadalejo.com
zahoorjury
Raul R20 Builder v/s avo cache builder
Postby zahoorjury » 19 Nov 2007, 22:37
Hi Raul, Good work. i tried your software, it is Ok, but the Avo cache builder is still refusing to add a personility made by your software. I mean for the time being we can use those files which are prepared by ourself but after a WIPE ALL. they lost.
Your R20. builder also shows Manufacturer UNKNOWN , while adding the file into Avo cache builder.
Do you have any solutions ?.
regards. zahoor jury
Raúl
Postby Raúl » 19 Nov 2007, 22:47
Hi zahoorjury,
Cache Builder refuses r20 files made by my app?, I need to try that because never saw that, maybe you can send me your generated R20 for test with it. Do you receive any error popup or so?
The manufacturer on cache builder is determined by the begining of the r20 filename, example, if your r20 filename begins with MT, Cache Builder will show that manufactures is Martin... and so... just use 2 first characters to determine manufacturer, try it.
Regards,
Raúl Gómez
zahoorjury
Amazing Instant reply
Postby zahoorjury » 19 Nov 2007, 22:57
Hi Raul, Glad to see your post as east, i will try your suggestions and let you know.
regards.
gnamusic
Re: Raul R20 Builder v/s avo cache builder
Postby gnamusic » 20 Nov 2007, 02:02
zahoorjury wrote:Hi Raul, Good work. i tried your software, it is Ok, but the Avo cache builder is still refusing to add a personility made by your software. I mean for the time being we can use those files which are prepared by ourself but after a WIPE ALL. they lost.
why its show manufacturer UNKNOWN ?, i never show rejected by cache builder. step by step is so important, including the info filling such author name manufacturer or else..
hello raul, i hope new version of your software soon will be available, speacially r20 editing, this feature is so importan to learn how other manufacturer wirting script r20 for their products.
thank a lot
Raúl
Postby Raúl » 20 Nov 2007, 22:18
gnamusic wrote:hello raul, i hope new version of your software soon will be available, speacially r20 editing, this feature is so importan to learn how other manufacturer wirting script r20 for their products.
New version will follow shortly. Because I'm working quite hard on it right now.
Next features released will be:
- Multilanguage interface
- Edit Macros
- Custom shapes creator
and probably edit R20, if I can finish testing.
I hope you can help me translating the program to your own languages when it become released :)
Regards,
Raúl Gómez
gnamusic
Postby gnamusic » 21 Nov 2007, 01:40
translate in my language -i will help you, tell me what to do ?
Raúl
Postby Raúl » 21 Nov 2007, 09:08
give me your mail via private message and I will send you the file to translate.
Raúl Gómez
Raúl
Postby Raúl » 20 Dec 2007, 20:35
Merry Christmas to all!
Here you go my gift to all of you:
A new version of R20 Builder is ready to download/update.
http://www.albadalejo.com/raul/software/R20PB.zip
or click "Check for Updates" button on the application.
This new version includes a re-designed multilanguage interface, now it owns 3 languages (english, spanish and portuguese), if you want to add your own language and wants to helpme translating contact me.
Now, this version is ready to release edit R20 files feature, that will becoma active shortly!
Also contains internal code to allow edit Macros (soon as well), and a new feature that will allow you to create and edit your own Shapes!!
I hope you have fun with this stuff, and have a nice hollydays upcoming!
Best wishes to you!!
Raúl Gómez
iadwm
Postby iadwm » 21 Dec 2007, 01:14
Raúl,
Very much looking forward to the new features! But, my installed version didn't want to update and the link in your post didn't erm....link.
Actually, your site appears to be down ?....
Thanks,
Andy
John Peel
www.iadwm.com
Raúl
Postby Raúl » 21 Dec 2007, 08:33
Try again Andy,
Both ways worked fine for me... maybe you try it in a server's "coffe time" hehe
Best regards,
Raúl Gómez
Olie
Site Admin
Postby Olie » 21 Dec 2007, 11:55
Hi Raul
Just a thought have you included the recent changes to the R20 personalities in your software. You may need to do this as not having them may cause some users problems.
The two changes are the addition of the NAME tag and a new attributes T=Red, U=Green, V=Blue, while B=Cyan, C=Magenta, D=Yellow remain unchanged.
Raúl
Postby Raúl » 21 Dec 2007, 12:01
Hi Olie,
Ok, thanks, I'll look into this asap!!
What's the NAME tag purpose? can you explain so I can put it on my soft your explanation as "help". Thanks.
Raúl Gómez
Olie
Site Admin
Postby Olie » 21 Dec 2007, 12:12
The name tag has the format:
NAME "Manufacturer Name" "Fixture Name"
it comes after the DEVICE tag and allows you to specify a long fixture name. It is used in the Pearl Expert and Pearl 2008 software to list the manufacturers and fixtures with more intelligible names. If you do not include it then these desks will not see the personality.
Users browsing this forum: Google [Bot] and 147 guests
