Whats the best way to make a blackout?
just slide down the MASTER fader don't work well, cause if I have in page A sub 1 e 2, in page B sub 3 e 4 and in page C sub 5 e 6, and make a blackout with the MASTER fader, when I raise up the fader don't will activ the previouse sub's, and will activ sub's 1 to 6 from the page were I stay...
What's your opinion?
Regards
Blackout
Yup. Very annoying fault. Swop was the same for a long time, but is now fixed so you could use this if instant blackout is ok.
But essentially the best way to blackout is to lower PB's/presets. Silly, but true.
FWIW I did highlight this problem again recently, notably the inconsistency between consoles - Expert works correctly with masters but not with Swop.
Users browsing this forum: No registered users and 64 guests
