Hi.
I've tried to make the fader take contol of ex. radius of a circle. didn't manage it.
This can be done in an easy way, I've heard, but how?
Thanx,
K. Ivar Skjorestad
Effects on Pearl...
Create the shape and store on a Playback
In Program Mode:
[Shape Generator]
[Playback Parameters]
Hit Playback Swop button of shape
Hit [Toggle Size] Softbutton until display reads Size is Timed.
This should automatically set Playback to Mode 2.
That's it!
You can also use these 'timed' parameters with an LTP fade time to fade in a shape.
Hope that helps.
Nic
In Program Mode:
[Shape Generator]
That's it!
Hope that helps.
Nic
galaxyshow
How?
Hi, could you tell me how to make a Fader controlling the Shape Speed on AZURE?
Guest
Yes, similar to hog.
This gets rid of the messy 'snap' to the start offset of a shape. The use of 'timed' and LTP fades was never documented.
The only other way to avoid a 'snap' is to set the size to timed and manually fade the shape in and out on mode 2 - though this is a compromise.
I don't recommend setting a LTP fade time and using the fader on mode 2 at the same time!
Best regards,
Nic.
Best regards,
Nic.
Users browsing this forum: Google [Bot] and 89 guests
