On a Pearl 2004, is there a way to...
iadwm
Postby iadwm » 05 May 2007, 18:05
So if it doesn't restore the dipped output when you lower the mode 3 memory - what's the point? Or do you mean it's meant to and just doesn't work properly? In which case, I can say it again - what's the point!
John Peel
www.iadwm.com
CoenCo
Postby CoenCo » 05 May 2007, 18:29
From my memory, the fun part was:
If you raise it all the way to 100%, output from other memories wont be restored.
If you raise it to 95%, it acts like a mode2, and lowering it restores the other memories.
But this was all a long time ago :)
Postby niclights » 05 May 2007, 20:00
From the manual:
· Mode 3 - Crossfade cue. All channels, including intensity channels, will fade to the settings in the new cue. All other cues fade out and all other active playbacks become inactive; if you need to re-fire a playback, take the fader to zero and put it up again.
It's not wrong, just a different thinking.
Users browsing this forum: Bing [Bot] and 64 guests
