personality for HES color command
iain1@rogers.com
Hi Avolites type persons, have you fixed the bugs in the HES colour command personality file? It's not that it doesn't work, it's that everything is mixed up. Cyan is zoom on the cyan wheel etc, not impossilble to get yer head around, just irritating when programing at speed. Iain
galaxyshow
I'm a little unsure of what the problems with it are, since the DMX output is what the user manual on High End's website for the Color Command suggests it requires - see page 41 of this.
If you can first check that you've got the most up to date version of the file from our personality library, and then tell me exactly what (if any) issues there are with it, then I'll do my best for you.
Phil Rogers
Phil Rogers
galaxyshow
Sorry.... I also meant to add this....
If you find you have any other problems with fixture personalities, or you need one that's not been created, could you use the request and bug forms in our Fixture Personality Library.
Many Thanks
Phil Rogers
Many Thanks
Phil Rogers
Users browsing this forum: Bing [Bot] and 69 guests
