Quartz missing USB Auxiliary Panel
naaman
Postby naaman » 10 Jul 2025, 19:55
using Quartz
after installing V18 from v17
the side keys A-G keys are not working
there was an error on the usb update process , and i didnt capture the error , pressed retry a few times and eventually it passed
but now the Auxiliary Panel 1 Panel is not showing in the USB Expert
and the side keys are not working...
everything else seems fine
any one knows any thing ?
thank you
Re: Quartz missing USB Auxiliary Panel
Postby niclights » 11 Jul 2025, 10:07
It looks like you have already opened a Help Desk ticket regarding this. To avoid confusion it may be best to continue with that.
naaman
Postby naaman » 11 Jul 2025, 11:24
thank you im with support right now on email but i need to fix this as quickly as possible...
Postby niclights » 11 Jul 2025, 12:09
Help Desk is almost certainly the best and fastest way for this as it looks like it is hardware related. I believe you have been contacted by support already.
naaman
Postby naaman » 11 Jul 2025, 13:02
yes , problem solved , usb driver issue , solved bu help desk . thank you :)
gkays
Postby gkays » 30 Aug 2025, 15:15
Same issue after updating my Quartz to v18. Panel update failed on the Auxiliary panel and now has disappeared and isn't functioning. Tried Repair USB Drivers in USB Expert. Was there somewhere else to update drivers? Aux panel doesn't show up in Device Manager either
Gareth Kays
CEO
GK Productions Australia
http://www.gkproductions.com.au
Users browsing this forum: Google [Bot] and 72 guests
