Trying to create a macro that replaces a colour pallete for a other colour.
step 1 blind active
step 2 select group (for example) 1
step 3 select colour ID:1 (for example)
step 4 merge or replace on ID:2 (for example)
step 5 clear
step 6 blind inactive
END MACRO
I based my macro on the PaletteChaseChanger (V3) on the avolites wiki ( https://www.avosupport.de/wiki/macros/e ... changer_v3 ), but I can't get it to work.
I have this right now:
<?xml version="1.0" encoding="utf-8"?>
<avolites.macros>
  <macro id="Replace FX1 White" name="001 FX1 White">
    <sequence>
      <step pause="0.5">ActionScript.SetProperty.Boolean("Programmer.BlindActive", true)</step>
      <step pause="0.5">Programmer.SetBlindMode(false, 0)</step>
      <step pause="0.5">Attribute.Mask.IncludeAll("Palette")</step>
      <step pause="0.5">Group.RecallGroupNumeric(91)</step>
      <step pause="0.5">Palette.ApplyPalette("Location=Colours,1,2", false)</step>
      <step pause="0.5">ActionScript.SetProperty("Palette.CurrentPaletteHandle", handle:"Location=Colours,1,397")</step>
      <step pause="0.5">Palette.StoreCurrentPaletteReplace()</step>
      <step pause="0.5">Programmer.Editor.Clear(Attribute.Mask.Clear.Value, Programmer.Editor.Fixtures.Clear.Presets,
        false, Expert.ClearMenu.FadeTime)</step>
      <step pause="0.5">ActionScript.SetProperty.Boolean("Programmer.BlindActive", false)</step>
    </sequence>
  </macro>
</avolites.macros>
Seems to me that the macro doesn't select the group correctly and only replaces the palette. The palette just becomes blanc after using the macro
Can someone check if I have done it correctly?
