Change handle userNumber using WebAPI not working
Discussion and chat related to developing interfaces to the Titan software using the web API.
vsingmalaysia
Postby vsingmalaysia » 27 Feb 2024, 14:07
Hello There, I found out few weird behaviour in webAPI
in Macro it works,
        <step>Handles.SetSourceHandleFromHandle("cueHandleUN=1")</step>
        <step>ActionScript.SetProperty("Handles.CurrentUserNumber", userNumber:2)</step>
        <step>Handles.SetUserNumber()</step>
        <step>Handles.ClearSelection()</step>
It successfully change the userNumber from 1 to 2
but when it comes to webAPI
SetSourceHandleFromHandle only works in titanId, handle_userNumber is not working and when i proceed to setUserNumber , it says "Error: User number already in use" but userNumber 2 does not exist before hand at all
   http://localhost:4430/titan/script/2/Handles/SetSourceHandleFromHandle?handle_titanId=1869 //only working with handle_titanId
   http://localhost:4430/titan/script/2/ActionScript/SetProperty?id=Handles.CurrentUserNumber&value=userNumber:2 //not sure is this correctly written
   http://localhost:4430/titan/script/2/Handles/SetUserNumber //error here saying ""Error: User number already in use"" note: I''ve already change backe userNUmber 2 cueHandle to 1
   http://localhost:4430/titan/script/2/Handles/ClearSelection  //working
need help here thanks.
Re: Change handle userNumber using WebAPI not working
Postby icke_siegen » 29 Feb 2024, 13:06
With massive help from Gregory I am happy to post the solution:
http://localhost:4430/titan/script/2/Handles/SetSourceHandleFromHandle?handle_string=cueHandleUN:1
http://localhost:4430/titan/script/2/ActionScript/SetProperty?id=Handles.CurrentUserNumber&value_userNumber=2
A little explanation:
  • in order to provide the usernumber to the first command you need to tell Titan that this is in the scope of playbacks or cues - as there might be a usernumber 1 in fixtures, in groups, in palettes, in playbacks and elsewhere, usernumber isn't unique. For macros the notation for this casting is
    "cueHandleUN=1"
    and in the web API you need to write
  • casting the value is also the issue in the second line: instead of
    value=userNumber:2
    it is
    value_userNumber=2
  • and as soon as these values are correctly submitted, line 3 doesn't throw an error any more
I'll put this in the wiki as well.
vsingmalaysia
Postby vsingmalaysia » 08 Mar 2024, 05:35
I tested and it works in Version 16, with my T2 dongle, Thanks!!
but in version 11.3 Avolite Titan Simulator (online activated), the
have this issue
"Error: Object of type 'System.String' cannot be converted to type 'Avolites.Titan.Controllers.Handles.Handle'."
just curious if version 11 have another casting? and where can i check all the parameters?
I am working on making my place lighting able to be controleable through mobile phone using webApi.
Postby icke_siegen » 11 Mar 2024, 16:07
I already tried various things to make this work in v11 but didn't succeed. I just asked Gregory again, maybe he has another approach.
What you can do is using the location in the current page with
http://localhost:4430/titan/script/2/Handles/SetSourceHandle?group=Playbacks&index=0
but this is probably not what you want.
Maybe write a JS function to get the Titan ID of the playback with UN 1 from titan/handles?
Postby icke_siegen » 13 Mar 2024, 07:18
Okay,
again this is all Gregory, and I am only the delivery boy:
for cues, cuelists and chases the first line must read (respectively)
http://localhost:4430/titan/script/2/Handles/SetSourceFromUserNumber?handlePath=Handle.Playback.Cue&userNumber=1
http://localhost:4430/titan/script/2/Handles/SetSourceFromUserNumber?handlePath=Handle.Playback.SteppedPlayback.CueList&userNumber=1
http://localhost:4430/titan/script/2/Handles/SetSourceFromUserNumber?handlePath=Handle.Playback.SteppedPlayback.Chase&userNumber=1
It looks like there is no solution to select playback 1 regardless its type. hence you'd probably need to run this three times, once for cues, for cuelists, and for chases.
Users browsing this forum: No registered users and 7 guests
