Pro DJ Link - No Waveforms
funkyant
Postby funkyant » 29 Jun 2023, 17:43
Tiger Touch II, latest Titan, Pioneer DJM V10 and 4 x CDJ3000, all on the same network.
ProDJ Link Bridge running on the Avo sees all the devices, all come up green.
Resolume, on the same network works perfectly, connected to bridge on the Avo - Track art, all player data, etc, behaves as expected.
Titan can read track names, BPM, play status and track counter fine. But no waveforms.
I've tried running bridge on the Resolume PC and the result is the same. Tried it with 2 different consoles and they both don't show waveforms.
Any hints?
Re: Pro DJ Link - No Waveforms
Postby icke_siegen » 30 Jun 2023, 12:09
As far as I know the waveform display depends from Rekordbox (separate software). From the Titan release notes:
Note that in order for the waveforms and play head position to work correctly tracks need to have been
analysed by and exported from RekordBox (the Pioneer equipment does not do any of the analysis and also
relies on this for the waveform displays).
Have you tried this?
funkyant
Postby funkyant » 30 Jun 2023, 12:23
Yes of course, as I said, it works perfectly with resolume and now tested with showkontrol and that works fine also.
jck136
Postby jck136 » 19 Jun 2024, 21:45
Hi! Hope everything is find for you. Does you have a solution for the waveform? Thanks
