Custom Chase/Cuelist Order
tomhoef
Postby tomhoef » 29 Dec 2022, 19:59
Hi all,
I've started learning Avo, but I'm looking for some features (coming original from MA/Hog).
The first feature I'm looking for is a way to do custom order linking of cues, so after cue 1 go to 2 then to 4 but skip 3 for example. I know you can change the order of cues by just rearranging them or probably using macros (which is only possible in a cuelist not in a chase?) but that is not what I'm looking for.
Let me know if I'm missing something
Re: Custom Chase/Cuelist Order
Postby Gregory » 30 Dec 2022, 13:33
There isn't really any function to allow you to change the default next cue in a chase or cue list, however in the specific example you gave you might be able to mark cue 3 as disabled which would cause the software to skip directly from cue 2 to cue 4. However this depends on the cues being in the correct order and prevents the disabled cue from being fired until it is reenabled.
