Azure 2000 (Software 2003) Memory Full Problem,
BasVal
Postby BasVal » 19 Jul 2004, 08:04
Hi There,
I'm working on a nightclub with the Azure 2000.
We're using this desk for only one week now, and only have programmed 2 banks with Presets (A & B) after that we noticed a lot of strange problems, move's were not working anymore and copying (colour, gobo, prisma) presets was IMPOSSIBLE.
After a while we found out that the Avolites Azure 2000 was out of memory space.
We're using about 4 different spots (10x Robe Wash XT, 10 xRobe Spot XT, 50 x Showtec Genesis 3 & 2 Strobo's.) And only have programmed Bank A & B
We saved all info to disk, and then used the "Wipe All" function.
Then placed back the "show from disk" and suddenly we've had 62% memory free. Is this a known problem????
The manual also says that using the "CUT" function has to work like "ctrl-x" in windows and saves the preset to "Temp Memory" before u "Paste" this preset to another button.
When i use the Cut function my preset is removed but i can't Paste this to another position.
We also had a chip deliverd with the Azure Table, what's should we do with that ??
Thanks for your help............. :?:
BasVal
Register
Postby BasVal » 19 Jul 2004, 08:26
I forgot to register.
now it's done........... :wink:
. . : : B a s V a l : : . .
www.BasVal.nl
www.deSenaat.nl
Guest
Postby Guest » 23 Jul 2004, 22:27
I have a similar problem with my azure 2000, when cuting a memory, sometime the desk is "Out of memory", but by reseting it all is OK.
I don't understand why.
BasVal
Azure Memory Problem
Postby BasVal » 24 Jul 2004, 12:53
Yes, my problem is just the same.
But it only worked when i made a full back up, did WIPE ALL, and reload show.
My guess is that when u use CUT it keeps the preset in the memory but i doesn't go out there, because when you do PASTE there is nothing to PASTE.
I've already contacted Nick from Avolites and he's busy with my problem (he has a back up file from our console when we've had the problem)
www.BasVal.nl
www.deSenaat.nl
galaxyshow
Postby galaxyshow » 06 Oct 2004, 20:42
With AZURE 2003 Soft, I can't CUT a memory then paste it.
After resetting, wipeall, same probleme....
toby_prin
Re: Azure 2000 (Software 2003) Memory Full Problem,
Postby toby_prin » 08 Dec 2016, 20:25
Did this ever get solved?!
I'm guessing as it's 2016 now and I can't find any new firmware, then no is the answer, but hey, bump bump ;)
Perhaps it's time to sell the much loved Shadow :(
Users browsing this forum: No registered users and 119 guests
