Beampix 14
Marcelo damian cajal
Beampix 14
Postby Marcelo damian cajal » 31 May 2022, 16:42
Hola ,buenas tardes. Tengo un problema con el fixture del beampix 14. El white warm no tiene control independiente y no puedo usar el RGB solo. Alguien para ayudarme. Intenté modificar la librería pero sigo sin poder encontrar el error. Muchas gracias
Re: Beampix 14
Postby niclights » 31 May 2022, 17:05
With the library version of the personality you should be able to control the parts independently by selecting the relevant cells of selected fixtures, either from the handles at the top of the Attribute Editor window or by unfolding the fixture(s). For example the 'RGB*' cells control just the RGB part and the 'White*' cells control the warm white parts.
