Virtual Keyboard "Auto Open" is not saved
ofamin
Postby ofamin » 25 Jan 2022, 16:00
Using Titan v.15 with a Lenovo ThinkPad X1 Yoga in Tablet Mode I don't have access to the physical keyboard.
Everytime I open a showfile I have to go in "Set Legend" and select "Auto Open" to activate the virtual keyboard.
This honestly seems like a trick or a workaround solution.
If I save the showfile and reopen it, this option is was not saved, so I have to do it again.
Would it be possible to save this preference with the showfile and/or add an option (User Menu) in order to activate/deactivate the virtual keyboard ?
Thanks! :)
Re: Virtual Keyboard "Auto Open" is not saved
Postby Gregory » 25 Jan 2022, 16:50
The problem is the software is attempting to be helpful and when it detects a keyboard it disables the Auto Open mode as it assumes that you want to use the physical keyboard instead. Perhaps if this was separated out so that it would treat manually toggling the Auto/Manual toggle separately. Making the options accessible elsewhere could also be a possibility although probably as a per device setting rather than per user.
Users browsing this forum: Baidu [Spider] and 71 guests
