Key Profiles
watty
Key Profiles
Postby watty » 03 Dec 2021, 17:19
Tried this on Facebook but no response.
I'm not sure if I am missing something or doing something wrong with key profiles, but if I create a Rate Master and create a new key profile, there is an option in key profiles to change button actions for "Masters" & then "Standard Masters". If I change a blue key to "release", it will not change the action of the button even though "release" appears to be an allowable choice. Usually Flash & Tap Tempo.
This issue appears to affect quite a few button options whereby it seems that it should have worked but doesn't.
Can any one shed any light on this?
Forgot to say tried it in V14 & V15 in Titan Go & Titan Mobile.
Re: Key Profiles
Postby niclights » 03 Dec 2021, 17:44
Unfortunately I believe this is a display fault specific to masters in Titan Go where the blue and grey buttons always show as Tap Tempo and Flash regardless of the assigned action. The action itself should work correctly. Consoles display the assigned action. (#68786)
watty
Re: Key Profiles
Postby watty » 04 Dec 2021, 15:15
Thanks Nick. I'll look into it further. Will it get addressed as a bug fix for the next version? I believe the same issue exists in V14 & V15!
