Bug? Autoload does not "Go On Target" for chases
revenant
Postby revenant » 18 Oct 2021, 11:09
Titan Go V15
Autoloaded chases do not "Go" when autoloaded with [Go on Target] option.
Repro as follows -
1. Start new show
2. Create a 4 step chase
3. Set Link on each step of chase to [Wait For Go]
4. Create a 2 cue list
5. Add the previously created chase to the Autoload for each cue of the list and set the autoload option to [Press Go On Target]
6. "Go" on the cue list
7. Observe, each go on the cue list will load the chase but the chase step/cue does not go.
This issue is only present for autoloaded chases, cue lists work as expected.
The setting of the chase step links to [Wait For Go] is for clarity of the repro only as I would assume that [Go On Target] on a running chase step with [After Previous] link would (when working as expected) advance to the next step in the sequence?
Re: Bug? Autoload does not "Go On Target" for chases
Postby Gregory » 27 Oct 2021, 13:34
Thank you again for your report. As far as I can tell the engine does not support the Go On Target autoload option on anything apart from cue lists and possible never has however in the UI it incorrectly shows you that option for chases. I will log both aspects, the ideal being that the functionality can be added to chases but in the meantime we should probably remove the option for a function that isn't actually implemented.
revenant
Postby revenant » 28 Oct 2021, 09:20
Thanks for taking the time to investigate and log the issue Gregory.
As the intention is to remove the options until the underlying feature is available then you should probably note, if you haven't done so already, that the user manual should also be revised to remove mention of these options for chases as currently in the section detailing Autoload a playback within a Cue List it states...
For a chase or cue list, softkey B lets you select whether to load the playback from the start, to start at a specific cue, or to press Go on the target playback.
As the manual makes reference to these options for chases it would suggest that the underlying functionality was probably there or intended to be there at some point previously.
