Macros in showfile on another desk
htevents
Postby htevents » 03 Aug 2021, 19:51
Hello all,
When programming a show on a pc or just any Titan desk and using custom macros in that show. When I save the showfile on a USB stick and load the show into another desk, will the macros also be present in the show on that desk or do I need to transfer any macros manualy?
Re: Macros in showfile on another desk
Postby icke_siegen » 05 Aug 2021, 14:17
Yes, the macros are stored in the showfile and transfer with it, without the need to copy the macros. This is true for recorded as well as for programmed macros. I just tried this - no problem at all.
htevents
Postby htevents » 06 Aug 2021, 09:11
icke_siegen wrote:Yes, the macros are stored in the showfile and transfer with it, without the need to copy the macros. This is true for recorded as well as for programmed macros. I just tried this - no problem at all.
Thank you very much for the quick answer.
outputaudio
Postby outputaudio » 22 Nov 2023, 19:45
I have the same question but the other way around:
When i save a showfile from a desk on a usb and load this into pc suite, i have all the macro's in the showfile.
But can i export these (custom)macro's to xml files again?
Postby icke_siegen » 23 Nov 2023, 08:09
There is a function which can be used in a macro to export macros - see https://www.avolites.de/wiki/macros/example/exportmacro. Install this macro. Running it exports the macro with the usernumber 1 as XML to your usermacros location. You can then simply set other macros to this usernumber and export them...
outputaudio
Postby outputaudio » 26 Nov 2023, 16:46
I will check this out, thx!
