The titan PC suite won't start on my PC anymore, same problem for titan mobile, titan one... I started titan mobile, the software said it couldn't start a session. When I restart, the software keeps starting up. The titan engine won't start which is probably the problem. Currently running version 11.4.
I had this problem as well for about a month ago, but removing the SHUTDOWN.d4b file solved the problem. However this time there was no SHUTDOWN.d4b file in my directory (hidden files is turned on). I already reinstalled the software while removing all files, but now it seems like the sotware isn't installed correctly: in "c:/Users/Username/AppData/Roaming/Avolites/" is only a folder "Icon Library" and "Titan Mobile", if I remember correctly there should be folders with the installed versions of titan as well? I also tried to shutdown firewall, but that doesn't help either.
Has anyone an idea how to solve this, can I force the titan engine to start somewhere?
Thanks in advance,
Michiel
Titan PC suite won't start
Michiel3000
Bruno Costa
Re: Titan PC suite won't start
I have the same problem now.
Any help?
Regards
Any help?
Regards
If you haven't already please see the following Titan Troubleshooting guides:
Titan: Grey Pulsing Screen
and particularly:
Intel Command Center Service Prevents Titan from starting
Chances are it is the latter and disabling the Intel Command Center Service will fix.
and particularly:
Константин
Спасибо! Не запускался Т1. Перепробовал всё, что вы тут предлагали. Помогло только последнее: отключение службы Intel(R) Graphics Command Center Service.
Константин wrote:Спасибо! Не запускался Т1. Перепробовал всё, что вы тут предлагали. Помогло только последнее: отключение службы Intel(R) Graphics Command Center Service.
I cannot find this services on my computer. im having the same problem. I dont have Intel(R) Graphics Command Center Service also...
