Can anyone help with the following regarding location and selection of personality files?
I am keen to understand a few points regarding personality files:
1. Is there a way to confirm which personality file a patched fixture is using in a show. i.e. Whether it is using the factory personality or a specific custom personality?
2. If I patch a fixture and there are there are two custom personalities (if you can have two or more) will I automatically have a choice to chose between the factory and custom personalities when patching?
3. If I create a custom personality and save it, what steps would I need to take to apply the custom personality to a set of fixtures which were previously patched using a different custom or factory version?
Thanks in advance for any help on this.
Personality files
Re: Personality files
1. User personalities have (User) appended to the fixture name. You cannot easily otherwise determine the actual file from which a personality was read.
2. You cannot have two custom personalities with the same name for a given fixture.
3. Use exchange.
3. Use exchange.
Pete Bridgman :: Avolites
You can also look in the Personality tab of the Fixture View window to see the history/comments for the personality. It is usually good practice to add these to personalities that you have changed, all factory personalities will include an entry for each update.
