Set only the dimmer on a fader
Hello everyone i've got a problem. I want to set my moving heads to a fader so I can fade the moving heads in whatever position they are. The problem is that if I program the MH under a fader, he automatically sets also the position under that fader and that is the thing I don't want. I definetly want only the dimmer at that fader. Is this possible?
Re: Set only the dimmer on a fader
Make sure only the dimmer information is in the programmer - for example CLEAR -> Select fixture(s) -> @@ (assuming you want them at full intensity). Then when recording toggle the mode to 'Channel' (Softkey A in the Record menu). This will record only controls in the programmer (ie. value is highlighted in the wheel display).
For cues that are already recorded you can remove unwanted controls by setting them to 'Off'. One way to do this is to view the cue (if it's a simple memory on one of the main playback faders you can double-tap the legend). Then in the cue view window select the cells that you want to remove and choose [Off] from the softkey menu.
clublights
you can also use group masters..... copy the group of fixtures to a fader, use playback options to change how the master works.
