T2 as audio input
watty
T2 as audio input
Postby watty » 19 Nov 2019, 16:47
I would appreciate it if anyone can help with the below question.
I have been told that the T2 can be used as an audio input when connected to a PC/Titan Mobile to create audio triggers.
If I connect a T2/Titan Mobile/PC running V12 and create a playback linked to audio triggers (which are not usually available with the Titan Mobile alone), what will happen A) if I open the show file without the T2 plugged in and B), try to fire the playback without the T2 plugged in?
Re: T2 as audio input
Postby Gregory » 19 Nov 2019, 17:36
You should be able to load a show file containing audio triggers (or any other kind of trigger) regardless of the hardware you have connected. If there is no hardware then you will not be able to receive the trigger but it should continue to exist although the Audio Triggers window will be disabled without the T2 connected. Triggers do not prevent you from using playbacks as you would normally, an action is only performed when a trigger is received, therefore it does not matter if a playback has a trigger associated with it nor whether the source of the trigger is available or not.
watty
Postby watty » 19 Nov 2019, 20:14
Gregory,
Many thanks for the clarification - Now all I have to do is try and get my hands on a T2 :) .
