Can anybody help?
kay
Re: LED LIGHTS Problem
Postby kay » 09 Oct 2006, 20:14
Aruvin wrote:HI Kay,
I am sure u will be having problem with ur LED Lights even if u get the patch correct on the avolites console.. :twisted:
Problems like flickering on the led lights once a while can be a pain in trouble shooting.. :lol:
From wat I find out thru experience, ur LED Lights may not be able to keep up with the dmx speed on the avolites console or rather most high profile console thus causing the problem..
Try using a low output dmx speed consle IE: the Jands 12 or if u get hold of a LANBOX or similar that can help u to slow down the dmx :twisted:
Cheers..hope it helps :lol:
Hi Aruvin, I did experience wat you said abt the LED fixture flickering.Man, and i 've tried solving the problems to my pearl2004.It just seems that i;m unable to figure out wats wrong with it.I'm troubleshooting for 2days infact.
Has anyone else encountered these similar problems? I did try out like wat nic said and still not solved.Haizzz.....i might wana try like wat Aruvin said but i wanna get it fixed on avolites pearl2004 first.
But i hope someone has a solution to it .... :(
Regards
KAY
Postby niclights » 10 Oct 2006, 00:26
I'm a bit confused now. The problem you described previously mentioned locate being wrong and inability to control intensity, but now you say they flicker. Can you explain exactly the problem?
It would be useful if you could post a copy of the personality here.
Olie
Site Admin
Postby Olie » 10 Oct 2006, 13:06
If you have a problem with LED lights flickering then could you please post your problem in a seperate thread.
The original personality problem has been resolved so I am closing this thread.
