If I simply "copy" a playback (In this case a cue list) from a playback to an executor, it copies fine, and all the step legends are there in both.
If I "Link-Copy" the Step Legends are all defaulted to the cue list name.
And also, I thought that "Link-Copy" would mean that if I update a cue list, it would update on all the ones it's linked to... but I tried adding a step on one, and it didn't replicate to the "link-copied" executor.
Copy Linked Cue Lists
Re: Copy Linked Cue Lists
Please could you confirm what software version you're using?
Pete Bridgman :: Avolites
Thanks.
Cuelist cue legends not being copied during link copy is a bug that we hope to address in a future software release; apologies for the inconvenience.
I'm not able to reproduce the behaviour with new cues not appearing in linked cuelists - could you confirm what steps you're following to cause this?
I’m not at my desk at the moment, but if I recall, I recorded a simple color wheel step change with one fixture, and about 9 steps. Recorded this cue list to a touch button.
I then link copied it to an executor, and the legends did not copy.
I then edited the touch button by using “unfold”.
I appended a step at the end and made a random colourwheel change.
Pressed unfold to save it. The touch button reflected the additional step, but the executor did not.
Interesting - I'm not able to reproduce this even when adding cues via [Unfold].
If you are able to reproduce this on a specific console it'd be useful if you could open a helpdesk ticket and attach the showfile and logs so we can investigate further.
Thanks,
Thanks,
Users browsing this forum: Bing [Bot] and 55 guests
