Up for sale is the Avolites Quartz Lighting Console LIKE NEW, its lightly used and has no scratches, this is the newest addition to the Titan Mobile family, its in prestine condition, its complete with on-board processing and a bright, vibrant 12.1” screen, in Avolites' smallest full-featured console. Super compact, measuring only 42.5cm wide, the Quartz is the ideal companion for all your lighting projects, from touring and festivals to clubs and one-offs.
Featuring the same high quality faders and hardware you’ve come to expect from Avolites, the Quartz can go anywhere you can, ideal for life on the road.
Offering full compatibility with Multi user, the Quartz is also perfect for use as a back-up or extra programming surface, cutting your programming time. The Quartz is ready to benefit from multi band Sound to Light Triggering functionality, offered in Titan version 9.
FEATURES
Most cost-effective fully featured console in the Avolites Titan range
Offering all the power of Titan in a super-portable package
Expand control surface with Titan Mobile Fader Wing
Front and rear-mounted USB ports
A bright built-in touchscreen, the latest on-board processing
Compatible with Titan Net backup, multi-user and DMX expansion
SPECIFICATION
General
Super compact form - just 42.5cm wide
4 physical DMX XLR-5 connectors
16 DMX universes from the console - 8192 channels
Compatible with Titan Net - up to 64 universes
Gigabit network port for Titan Net, Artnet and streaming ACN
Built in MIDI input, no extra boxes required
10 precision playback faders
3 high quality optical encoders
Compatible with Titan Remote
20 programmable macro buttons
Supports multi-band Sound-to-Light
Bright and vibrant 12.1" angled touch sreen with brightness control
DVI-D for external display
Headphone output
Button layout harmonised with the rest of the Titan range
Robust construction - built for life on the road
Conveniently located front panel mounted super speed USB3 port
Expandable with Titan Mobile Wing through dedicated USB port
Physical & Dimensions
Console only:
Dimensions (mm): 425 x 466 x 194
Weight: 8KG
Price: $3000
brnways@protonmail.com
FS: Avolites Quartz Lighting Console
- Attachments
- 1.jpg (244.66 KiB) Viewed 12207 times
- 5.jpg (212.24 KiB) Viewed 12207 times
