Hello everyone.
I have a Titan One and I would like to link my Ableton Live with Titan.
For that I spent MIDI through the network, my PC gets the MIDI (I checked with Pocket MIDI)
The problem is when I want to create a trigger on Titan no MIDI input is detected (the Learn On is activated)
Do you have any idea where it could get stuck?
MIDI not detected
Re: MIDI not detected
Titan only supports receiving MIDI via the physical 5-pin DIN port on Avolites hardware. Unfortunately this means it is only possible on the Titan Mobile or above. The option is still shown in the menu as the base software is used across all the Titan consoles.
Thank you very much for your answer, it's been a while since I was looking for and I didn't find this information
You have also the "Osimidi for Titan One" application that,for a price, you can add up to 5 devices to connect with the TitanOne software.
The only thing that I don't like is the faders of Titan One, because when you change the page, the fader stays there and don't reveal others faders under it. When you have a midi device with motorized faders and you want to change the page, the faders go to positions of the handles in the other page (like others Titan consoles), but with Titan One you can't get that...
If Avo team see this, is an upgrade that you can do? (Modify the way executors work)? Thanks
Osimidi does not use an official interface to Titan; not only do we recommend against users using it, we provide no support for it as it could cause instability in Titan up to and including application crashes.
Users wanting MIDI input using any Windows DirectX MIDI device (including USB MIDI and Network MIDI devices) can use these on all hardware from the newly-released T2 upwards in Titan V12.0.
Pete Bridgman :: Avolites
On the question of handles staying visible when you change page, please investigate the Handle Paging options (See section 8.6.2 of the Titan V12.0 manual).
dear master, if I buy a titan 2 dongle, what is the software to be paired with ? how to pairing midi control to the windows 10 operating system
I'm not sure I fully understand, but there are no special extra pieces of software required to make Windows (DirectX) MIDI work with T2; simply install the PC Suite and the drivers for your MIDI device and (as long as the device is compatible with Windows DirectX MIDI) it should work with no extra pieces of software required.
