Capture file not showing correctly
Timmy91
Postby Timmy91 » 09 Mar 2019, 22:28
I`m currently using capture 2018 quartett to make the design.
Console: Avolites Titan Mobile.
Issue:
When I load an atlas or Argo import into the Titan software. The stage box, stage elements are there in the correct positions.
but the generic 50mm pipes and lights are not where they should be. The lights are in default positions from the patch.
Does anyone have a suggestion to what this could be?
-Tim-
Re: Capture file not showing correctly
Postby niclights » 09 Mar 2019, 23:15
If you haven't done so already try turning off auto update in Titan Capture Visualiser Settings before loading the theatre.
Timmy91
Postby Timmy91 » 10 Mar 2019, 07:16
Thank you :D
That fixed my problem!
Issue resolved :)
