Diamond 4 : Select/Selected Fixture Order
Kohei
Postby Kohei » 14 Sep 2006, 02:00
Hi, I've got some question 'bout the selection order.
Can we select dimmers/fixtures with odd/even numbered fixtures?
And, how?
Kohei, Tokyo, Japan.
kay
Postby kay » 14 Sep 2006, 17:07
Hhi, are you looking for this?
Setting fixture order for Overlap functions
Normally the order in which the fixtures respond when using Overlap functions is set by the order in which you selected them. However you can change this:
1> Unfold the chase.
2> Press B [Set Cue Times] and press the Swop button of the cue you want to edit.
3> Press F [Advanced Options] then I [Set Fixture Order]
4> The display below the fixture presets changes to show the order on the bottom line.
5> Reorder the fixtures by typing the start number on the numeric keys, then pressing the Select buttons in the order you want them. For example, to set the order of 8 fixtures, press 1 on the keypad, then press the Select button of the fixture to be first, then the Select button for the second, and so on. This display shows the first 8 fixtures in reversed order.
6> You can set multiple fixtures to the same number if you want them to change at the same time.
7> Press Up to finish setting the fixture order.
you can download Diamond4 Help file from here.
http://www.avolitesdownload.com/Downloads/Diamond4.stm
