V11 in TT V9.1
- zahoorjury
V11 in TT V9.1
Hi , I have T1 and a TT also with V 9.1( not TT 2) , is it possible that I run my T1 in my TT console and can switch between T1 and TT own V9.1 in the same console ?
Re: V11 in TT V9.1
I'm not quite sire what you are asking but assuming the Tiger Touch has the required hardware specification (the Pro upgrade) you can install v11 on it, when you do so the previous version (I.e. v9.1) will be kept so you can switch between software versions on the console.
Titan PC Suite including TitanOne does not natively support installing multiple versions at the same time like you can on the consoles. However there is a third party solution called Titan Switch that can allow you to do this.
Plugging a T1 dongle or running the TitanOne software on a console is not supported.
- zahoorjury
Re: V11 in TT V9.1
Thanks sir.
