i swear i read the manual and searched old topics but maybe my english is not good enough.
I hope you can fogive my question that could look stupid.
Is it possible to insert a cue between other two cues when i am in "normal" mode,not in theatre mode?
inserting a cue
The best way to do it is the UNFOLD functionality. Use it in program mode.
Press the UNFOLD-button (one of the blue buttons), then press the playback SWOP-button of your chase.
Now every fader represents a step of your chase (or cue-list if you prefer).
Set up the required look.
Press the softbutton marked "INSERT" (I think softbutton B) and select the playback SWOP-button where you want the chase step to be added. So for instance, if you want to insert a cue between step 2 and step 3, press the SWOP button of playback number 3.
Finally, press the UNFOLD-button again.
It is best to turn afterwards the key to RUN and back to PROGRAM again to optimize the memory pool.
