Window Properties Macro
- sideshowbond
Re: Window Properties Macro
but you cannot not properly set it that way, you can only cycle between the however many displays you have. And starting point depends on which screen the window has been opened last. Which means I can't pin a window to a specific page. Workspaces can do that so surely there must be a way
There is of course internal code that can do this however unfortunately this is not accessible from macros.
- sideshowbond
as a workaround I tried
with adb.Macros.screensecondary being
hoping I could fix windows to screen 1 when cycled while screen 2 is disabled but that doesn't really work either
<sequence>
<step pause="0.001"><menuLink id="Windows.Groups" stack="mainWindowStack" behaviour="PushOrRaise" maximised="True" regionId="secondary" /></step>
<step pause="0.001">UserMacros.RecallMacroById("adb.Macros.screensecondary")</step>
<step>Windows.SetWindowProperty.X("Windows.Groups", 0)</step>
<step>Windows.SetWindowProperty.Y("Windows.Groups", 0)</step>
<step>Windows.SetWindowProperty.Width("Windows.Groups", 1)</step>
<step>Windows.SetWindowProperty.Height("Windows.Groups", 1)</step>
<step>ActionScript.SetProperty.Enum("Windows.Groups.ButtonSize", "Fixed")</step>
<step>ActionScript.SetProperty.Enum("Windows.Groups.TextSize", "Global")</step>
<step>ActionScript.SetProperty.Integer("Windows.Groups.FixedColumns", 5)</step>
<step>ActionScript.SetProperty.Integer("Windows.Groups.FixedRows", 5)</step>
<step>ActionScript.SetProperty.Boolean("Windows.Groups.Pages", true)</step>
<step>ActionScript.SetProperty.Integer("Windows.Playbacks.CurrentPage", 0)</step>
<step>Windows.Scrolling.Vertical.Scroll(-100000)</step>
<step>ActionScript.SetProperty("System.ExternalDisplay.Enabled", false)</step>
<step>Windows.Stack.CycleActiveWindowRegion("mainWindowStack")</step>
<step>ActionScript.SetProperty("System.ExternalDisplay.Enabled", true)</step>
