No DMX Output
daithi12
No DMX Output
Postby daithi12 » 16 Jun 2018, 00:10
Im not getting any dmx output from B,C or D on a quartz.
Ive plugged in a artnet also and it seems to be the same.
Only A works on both Physical outs on the console and on the artnet node.
Ive assigned the outputs correctly i think
Line1 - DMX OUTPUT A Expert DMX
Line 2 - DMX OUTPUT B Expert DMX
and the so on for 3 and 4
What am i missing?
Re: No DMX Output
Postby Gregory » 16 Jun 2018, 00:52
Your settings sound to be correct from what you have said. First thing I would try would be to save your show, start a new show with the Wipe DMX Settings option turned on and then load your show again with the Load DMX Settings option turned off. This will reset the DMX settings back to default.
daithi12
Re: No DMX Output
Postby daithi12 » 16 Jun 2018, 07:02
Thanks Gregory,
Ya i should have mentioned i tried that also at a few points.
I've just managed to avoid it anyways. i dont want to say solved as i have no idea what happened.
I reloaded an old showfile, then reloaded my new showfile with keep current dmx settings on and all was good. The physical outs work perfect and the Artnet is working perfect.
The only thing i can think off is i transferred the file from a titan mobile so unless i have some bug on the file when bringing it over. thats all i can put it down to at the moment.
Ill have time again later next week to check it out. Im not a fan of the mysterious issues.
Thanks for your reply Gregory.
