Cant start new Titan mobile
akepaulsson
Postby akepaulsson » 30 May 2018, 20:55
I can’t start a brand new Mobile. It requests a license key and I have tried to install it from file and manually entered the code but the computer still requests a valid code. (TM-3074 and latest software). What to do?
Re: Cant start new Titan mobile
Postby Gregory » 31 May 2018, 01:26
Has the computer had any kind of Titan software installed on it previously? The temporary licence, which is the one you get immediately when you submit your request, is only valid for 14 days from the original installation date. Full licence requests are normally issued within 24 hours and do not have the 14 day restriction.
akepaulsson
Postby akepaulsson » 31 May 2018, 09:10
Yes Gregory, I have used the computer for Titan One until now. Is that a problem?
Postby Gregory » 01 Jun 2018, 09:30
It is not a problem however the 14 day temporary licence period will be measured from when you installed/started using the TitanOne. This will most likely have expired so you will require a full licence before using the Titan Mobile.
akepaulsson
Postby akepaulsson » 05 Jun 2018, 20:11
Thanks Gregory! You were spot on. Once I got the permanent “key” it works as expected.
