Static faders
Static faders
Hello. I am using a tiger touch running 10.1. I would like to make the static playbacks independent from the record stage mode. So I can run house lights, haze etc and not have to worry about recording them in. Is this possible? Many thanks Ben
Re: Static faders
There is no way to exclude fixtures from Record by Stage, any fixture with intensity above zero will be recorded. A workaround might be to patch houselights as LTP Dimmer as this won't count as an above zero level. Alternatively consider using Record by Fixture instead where only fixtures in the programmer will be recorded.
