SetGrandMasterFaderLevel
Discussion and chat related to developing interfaces to the Titan software using the web API.
sideshowbond
Postby sideshowbond » 28 May 2018, 21:42
Evening,
I'm trying to get SetGrandMasterFaderLevel to work.
a) the error I'm getting is "Error: Couldn't cast oldValue". Any hint on what I am doing wrong? I've been using the value it's been set to and random vlaues as oldValue.
b) is that function working without the oldValue argument?
Cheers
Re: SetGrandMasterFaderLevel
Postby Gregory » 28 May 2018, 22:18
Try passing the value null for the oldValue parameter without any quotes.
sideshowbond
Postby sideshowbond » 28 May 2018, 22:21
couldn't cast oldValue
titan/script/2/Masters/SetGrandMasterFaderLevel?oldValue=null&value=$$$
running via an html fader (on Sebs API Demo sheet)
Postby Gregory » 01 Jun 2018, 20:52
Unfortunately WebAPI is unable to handle that parameter type at present however you can use it in macros e.g.:
Masters.SetGrandMasterFaderLevel(null, 0.5)
Note that you need to have the Grand Master Fader user setting set to Enabled.
