Hi.
Is it possible to set the TOUCH key profile on a BPM Master, on the playbacks window, to TAP TEMPO?
I moved the BPM Master to playbacks window, set a new key profile with TOUCH --> TAP TEMPO, but the master goes to MAX VALUE.
thanks
AC
BPM Master on Playbacks window
acetaxidriver
Re: BPM Master on Playbacks window
Unfortunately not at the moment but should be possible in the next version.
acetaxidriver
It's possible to copy the macro "TAP TEMPO" into playback window, the macro is in SHOW LIBRARY -> MACROS.
Yes. This is not quite the same as it will only work on connected chases but it is a good option.
