Custom Key Profile
kovacika
Custom Key Profile
Postby kovacika » 21 Jan 2018, 04:23
Is there a way to have a key profile that uses the swop button to fire the first cue in a cue list or chase?
Re: Custom Key Profile
Postby Gregory » 22 Jan 2018, 12:32
If a cue list is not fired you can try using the Latch key profile option which will fire the first cue at full, subsequent presses will proceed to subsequent cues. Assigning the Go key profile will fire the first cue but will not set the level so if the fader is at zero none of the dimmer channels will output but all of the other channels will change.
kovacika
Postby kovacika » 22 Jan 2018, 15:23
Im looking for a way to go directly to the first cue, even if I'm already at different cue (say I am at cue 5, I want to jump back to cue one with one button press)
Postby Gregory » 22 Jan 2018, 15:32
Unfortunately that is not possible as a key profile, you could use a macro to do it however this would have to be on a separate button i.e. it could not be on the flash or swop key of the playback.
